cracked block??!?!?!?
Old Apr 9, 2007 | 11:37 PM
pssssst's Avatar
pssssst
Default cracked block??!?!?!?
hey my neon has been leaking oil since i got it... hence why i only paid $400 for it lol, but i havent been driving it at all until the problem is fixed and I was told it is a camshaft seal but im not positive and i know a cracked block is a possibility.... how would i know if i had a cracked block????
Old Apr 10, 2007 | 12:27 AM
johnneon's Avatar
johnneon
Default RE: cracked block??!?!?!?
i highly doubt u have a cracked block cause u probably would see the oil blowing all over when its running,,and if it was cracked u would know,,where about's is it leaking from??andcould u geta pic of where its leaking from,,!!
Old Apr 10, 2007 | 12:32 AM
pimpberetta's Avatar
pimpberetta
When my cam seal was leaking, it poured oil out as fast as I could pour it back in, literally.
Old Apr 10, 2007 | 12:37 AM
johnneon's Avatar
johnneon
it could be a number of things,,oil pan gasket-oil filter's not tight enough-bad valve cover gasket-crank seal-or like what pimpberetta cam seal!!ide check 1 of them thing's,,,good luck,,
Old Apr 10, 2007 | 12:46 AM
Captain Squalus's Avatar
Captain Squalus
in 95% of the cases of a cracked block it would leak coolant not oil.
Old Apr 10, 2007 | 12:57 AM
neisg1's Avatar
neisg1
[align=left]Check the camshaft seal, the oil sender unit, valve cover and head gasket.[/align][align=left]Can you tell where (what general area) it's leaking? [/align]
Old Apr 10, 2007 | 01:50 AM
spudsterier's Avatar
spudsterier
if the block develops a crack then its usually internal....mostly between the coolant and oil ports or the cylinder wall......if the block is cracked then it would show signs similar to a blown headgasket.....
if your motor leaks oil externally then it would most likey be a seal or gasket sumwhere
Old Apr 15, 2007 | 06:20 AM
pssssst's Avatar
pssssst
thanks every1
Old Apr 15, 2007 | 02:58 PM
neisg1's Avatar
neisg1
ORIGINAL: pssssst
thanks every1
So--did you solve the problem?
