o2 sensor
i have a header and it has one o2 sensor hooked up and the other is not would the mopar pcm ellimate that or would i need to hook that up or could i splice it in to the other one monted on the header any help would be great
[IMG]local://upfiles/50518/91C87B97A0B7497B99140E3D5A302366.jpg[/IMG]
when i put the turbo on my car i didnt hook up the downstream 02 sensor.....i just wire tied the plug behind the motor....got a check engine light, but no running problems...not that this helps or anything[&o]
Would what mess anything up? Leaving it disconnected? AFAIK, no...but someone else on these boards said that it will. Other than having the CEL lit, I don't know of any other problems.
what does the down stream o2 sensor control, would it mainly tell you if your cat is working or not
Trending Topics
ORIGINAL: formula21
AFAIK
caveman say huh
AFAIK
caveman say huh
ORIGINAL: formula21
