sensor location
Old Apr 19, 2007 | 03:03 AM
jfjohn's Avatar
jfjohn
Default sensor location
anyone know where that sensor is on the tranny that tells the reverse lights to go on when you move the gear shifter? 97 neon sohc. is there any interference in getting to it? can it be reached from the top or underneath the car?
Old Apr 19, 2007 | 03:29 AM
neisg1's Avatar
neisg1
Default RE: sensor location
MTX
http://i37.photobucket.com/albums/e6...pSwitchMTX.jpg
On the ATX the backup light switch is part of the park/neutral switch
ATX
http://i37.photobucket.com/albums/e6...tralSwitch.jpg
Old Apr 19, 2007 | 02:21 PM
jfjohn's Avatar
jfjohn
thanks. found it. just curious, is it possible that the transmission is clogged at that port where the switch goes in so there isn't any fluid pushing on the switch? could that port get clogged?
