95 Neon won't turn over
Old Apr 19, 2007 | 12:11 PM
Baltimorebiker's Avatar
Baltimorebiker
Default 95 Neon won't turn over
Hiya. I'm new here, found this place whioe trying to findsome info on why my 95 Neon won't start.
and I'm glad I did.
Anyways.....I have a 95 Dodge Neon.....please don't ask me why type of engine...I have NO idea. I'ma biker and know diddly about car engines.
What I do know is that for the 2 years I've owned it, the Neon has been a GREAT car, VERY reliable.
Until recently.
Last week, I went to go to work and the car just cranks but won't turn over.
Battery tests fine, so I know it's not that.
Any ideas, suggestions????
Old Apr 19, 2007 | 12:32 PM
das2123's Avatar
das2123
Default RE: 95 Neon won't turn over
First of all,[sm=welcomesign.gif]!
I would check the clean and tighten the battery posts and clamps and check all the connections to the starter. The neon is sensitive to battery corrosion. Do you hear the fuel pump priming when you turn the key to ACC-ON?
Old Apr 19, 2007 | 12:40 PM
Baltimorebiker
thanx!!!
yeah, I cleaned the battery posts with a baking soda solution, since they were pretty corroded.
and no, I don't really hear anything from the fuel pump. But then I never have.
I'll give tightening the posts a try......
Old Apr 19, 2007 | 12:55 PM
das2123's Avatar
das2123
When you turn the key you should hear the fuel pump prime. If you don't check the fuel pump relay and fuse in the PDC.
Old Apr 19, 2007 | 01:02 PM
Baltimorebiker
will do, thanks!!! you have been a HUGE help with this!!
