is your max speed 128 or max in 4th gear and i thought that is was 137 in 4th but i thinkit might have been how fast i got after i shifted in to 5th ill have to check
1st 2nd 3rd4th 5th final 1998-1999 R/T DOHC 3.542.12 1.361.03 .81 3.94 with 195 65 14 Speed Chart RPM Speed 3000 57.5 3500 70 4000 82.5 4500 95.00 5000 107.50 5500 120.00 6000 132.50 6100 135.00 6200 137.50 6300 140.00 6400 142.50 6500 145.00 6600 147.50 6700 150.00 6800 152.20 7000 157.50 + or - a few tenths info can be found by using your final drive ratio, tire size and gear ratio so 6400rpms in 5th (.81)gear with a 195 65 14 tire and some math you get 143
whats 9's in the 1/4 mile????
i dont even know anyone that can even get 1/2 way through 4th gear in the 1/4 mile...let alone 7k into 5th gear[&:]
not to mention the maricle it would take to get a neon into the 9's
