Crank Censor?
Old Apr 22, 2007 | 01:14 AM
EF_Hatch's Avatar
EF_Hatch
Default Crank Censor?
How hard would a crank censor be to replace? Thanks guys.
Michael
Old Apr 22, 2007 | 03:32 AM
johnneon's Avatar
johnneon
Default RE: Crank Censor?
this should help,,good luck
Old Apr 26, 2007 | 08:50 PM
EF_Hatch's Avatar
EF_Hatch
Is that in the engine bay? I head it was located in the trans..?
Old Apr 26, 2007 | 09:06 PM
spudsterier's Avatar
spudsterier
crank sensor is located on the back of the motor right above the oil filter
there is no reason for a crankshaft sensor to be in the trans....it would only be located on the block by the crankshaft
Old Apr 26, 2007 | 09:18 PM
EF_Hatch's Avatar
EF_Hatch
So if I was looking in the bay, is it under the power steering resevior? Clipped to a metal support between the block and the firewall?
Old Apr 26, 2007 | 11:14 PM
spudsterier
it is closer to the oil filter then the ps resivoir....its right above the oil filter.....
NOT connected to any brackets or anything....its right in the blcok
Old Apr 27, 2007 | 01:25 AM
das2123's Avatar
das2123
ORIGINAL: EF_Hatch
Can you not see the picture provided? It's not difficult to find. Have a look above the filter.
Old May 6, 2007 | 04:23 PM
EF_Hatch's Avatar
EF_Hatch
Yeah, I saw the diagram. I must be retarded because I cannot locate it or the oil filter. I have looked on the back of the block. I will go look again right now. I'm sorry guys, thanks for the help, as always.
Michael
Old May 6, 2007 | 05:00 PM
loud99R/T's Avatar
loud99R/T
so you cant find the oil filter? sorry if that sounds mean but wow
Old May 6, 2007 | 06:10 PM
das2123's Avatar
das2123
ORIGINAL: EF_Hatch
You have to jack up the car (put it on jackstands) and they get under the vehicle and look up.
