Amp Problem
Old Apr 23, 2007 | 02:54 AM
boxerjl2's Avatar
boxerjl2
Default Amp Problem
Check it Out Let Me Know What You Think
or you Neon driver into big systems?? my system has worked great but all of a sudden it started doing this i really dont know whats going on
http://www.youtube.com/watch?v=RbFRuv0g4FM
check out the video and let me know
its in my neon soi figured you could help
[IMG]local://upfiles/60625/DC6FE2D7CFEC437EB9AAD81DF5D8B196.jpg[/IMG]
Old Apr 24, 2007 | 01:14 PM
pimpberetta's Avatar
pimpberetta
Default RE: Amp Problem
Are you running RCAs next to your power wire from the front?
Old Apr 24, 2007 | 10:40 PM
boxerjl2's Avatar
boxerjl2
there not right next to it but they are close to it but ive been running it like it is for about 2 weeks i believe about that and it just started this
but i put in a new ground and power wire and Rca with still no success
Old Apr 24, 2007 | 10:42 PM
pimpberetta
PM Fryedoug(sp) he seems to know his audio.
Old Apr 24, 2007 | 10:55 PM
HabitatHxC's Avatar
HabitatHxC
You got some wires backwards Make sure that the are connected right, It may seem like it is, but double/triple check. The subs are getting some wierd signal.
Old Apr 24, 2007 | 10:58 PM
boxerjl2's Avatar
boxerjl2
i replace all the wires and its doing the same exact thing it was doing and out of the blue it just started doing it it was working just fine and then the other day i turned on my car and it happened so its not the wires
Old Apr 24, 2007 | 11:18 PM
HabitatHxC's Avatar
HabitatHxC
Mabye something is grounding out It looked like you had a mess of wires there, also makesure your amp isnt touching anything metal tahts on the frame...
Seconly my lil highs did that when i blew out the rcas in the back of the cd player. try it on someone elses car or cd player.
Old Apr 25, 2007 | 03:11 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
did you run your power wires along with the RCA's? the power wire should be run up the driver side and the RCA's should be run up the passenger side. you want to keep them as far apart as possable
Old Apr 25, 2007 | 03:16 AM
boxerjl2's Avatar
boxerjl2
lol.. weird someone else asked that not that i know of its kinda close but not touching or anything but my system has been working for a while it just stop but my RCA got cut open and the external wire and the internal wire were touching so i replace the RCA but with no changes
when i bolted my seat back in i set it on the RCA and it cut both sides of the wire and the outer ground wire with no insulation was being led to the other one with the metel on the seat bolt in place and on one side the middle wire was spliced into???
How Do I Know If It Is My Deck Becuz that would suck cuz i just bought it for about $150 which is alot of money to me.
let me know it has the three differant RCA outputs and none of them change the amps output but im guesing sinces there all RCA then if one is broken then there all broken??
HMMM
let me know
Old Apr 25, 2007 | 07:31 AM
HabitatHxC's Avatar
HabitatHxC
Yea I could be wrong, But If the wires connected, then Im thinking that it put power into the back of the cd player and fried the RCAs. So go to a friends house and use there cd player and see if it works. Or even take it to a shop and have them check it out for you.
