e brake handle
Old Apr 25, 2007 | 01:44 AM
jakedlee16's Avatar
jakedlee16
Default e brake handle
how do i get the stock ebrake handle of the car ...
Old Apr 25, 2007 | 10:50 AM
spudsterier's Avatar
spudsterier
Default RE: e brake handle
remove the center console
there are then 2 bolts that hold the handel to the floor....1 in the right rear corner and one in the front left..
once its unbolted, left the handel off the bolt studs.....becarful since the cables are still connected and are spring loaded....
then once you have the handle free, you can move the cable ends and free them from the pull cable on the handel.....(works like a bicycle brake)
