auto differential trouble
Old Apr 25, 2007 | 04:23 AM
geevee's Avatar
geevee
Default auto differential trouble
I recently purchase a 96 neon that I was told had a bad axle which was causing some noise. It turns out the axles and cv's are fine. When I removed the inspection cover over the differential I found several teeth missing on the crown gear.......I'm not a happy camper! Can the diff be removed without removing the tranny? could I least change the crown gear from this position? It seems with the axles removed and the diff bearing caps removed if I were to jack up the trans slightly I would have room to get the diff out.
Any suggestions would be greatly apreciated.
ps. what could possibly cause broken teeth on such a strong gear? ( in an automatic trans )
thanks again, smokey
Old Apr 25, 2007 | 07:35 AM
HabitatHxC's Avatar
HabitatHxC
Default RE: auto differential trouble
What can cause it, Well NEUTRAL SLAMS!!!! I busted up my tranny in about 4 slams, I learned my lesson. Your probably gunna have to drop the tranny. But if not YAY! good luck!
Old Apr 25, 2007 | 06:11 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
ORIGINAL: HabitatHxC
LOL moron
Old Apr 25, 2007 | 07:15 PM
HabitatHxC's Avatar
HabitatHxC
Hey I was sixteen and my other car before it was a geo tracker that didnt have enough power to bust the tranny doing neutral slams! But ive learned what not to do with these ATXs!
Old Apr 25, 2007 | 07:32 PM
spudsterier's Avatar
spudsterier
when i was 16 my stereo was stolen out of my car....the people nusted up the car a bit getting it out too...i ended up finding out where they lived so i tore the hell out of there yard with neutral drops....traded the car in about 2 weeks later with no tranny problems
Old Apr 25, 2007 | 07:52 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Haha nice Spud I used to do neutral drops in my Probe before I had the atx swapped to a mtx and when I picked up the car from the tranny place they said that it was good I swapped because the atx was almost ocmpletely done lol
Old Apr 25, 2007 | 08:29 PM
95neonriceeater's Avatar
95neonriceeater
i do neutral drops on my friend's quad and i launch off the back tires
