smokin neon,,
Old Apr 27, 2007 | 01:54 AM
johnneon's Avatar
johnneon
Default RE: smokin neon,,
anyone[&:]!!!!
Old Apr 27, 2007 | 02:47 AM
neisg1's Avatar
neisg1
Did you check or replace the PCV valve?
Old Apr 27, 2007 | 12:52 PM
johnneon's Avatar
johnneon
so my pcv valve can cause me to burn oil!!!
Old Apr 27, 2007 | 02:33 PM
neisg1's Avatar
neisg1
A stuck PCV valve can cause oil to be pushed/pulled into, the intake and burnt. For the price $5-$10 it’s certainly worth a try. Also, make sure the PCV connecting hoses are in clean and in good condition. I had this happen on my 95 and had to replace the PCV hose as the inner surface was rotted and crumbling and kept clogging the PCV valve. It made a difference from 3000 mile oil change without having to add oil to being down to the add mark every week or so.
Old Apr 27, 2007 | 07:33 PM
johnneon's Avatar
johnneon
ok ill change it when i get a chance,,but i thought that if it was clogged it would stall,but im not sure,,!!!
Old Apr 28, 2007 | 02:08 AM
neisg1's Avatar
neisg1
If the PCV is stuck open oil can be sucked into the intake (by the engine vacuum) . If it’s stuck shut it causes pressure in the crankcase that can force oil past the rings.
