i need a this asap
Old Apr 28, 2007 | 11:52 PM
spudsterier's Avatar
spudsterier
Default i need a this asap
i need to know if anyone has one of these sitting around that they want to get rid of for cheap.....i need it asap.....[&:]
all of my suspension is done except for this thing...the bolt is stuck inside the bottom hole for the rear control arms...and then i snapped the bolt head off...
the one i need is for the rear passenger side....and if anyone happens to have the long *** bolt too, let me know....i think this is one of the only pieces that i dont have in the garage[:@]
[IMG]local://upfiles/29901/7AEEB42B4E024C27AD7B03471D274AFC.jpg[/IMG]
Old Apr 29, 2007 | 02:42 AM
NEONRT98's Avatar
NEONRT98
Default RE: i need a this asap
Bah! I wish you would have said something before! I could have brought it to Iowa! Let me look once I get back to Ohio and I will get back to you... I think I ended up cutting my stuff off.. so let me look!
Old Apr 29, 2007 | 12:44 PM
spudsterier
that sux..... i really need it so that i can set my car back on the ground[&:]
i just need one that doesnt have the bottom bolt stuck in it like mine was[:@]
Old Apr 29, 2007 | 01:38 PM
racerx55's Avatar
racerx55
as far as the bolt goes, get a long piece of grade 8 all thread and put a nut on either side, that holds up on the race cars.
good luck getting that bolt out, theyre hell. ive had to torch it till its glowing red and drive it out with an air chisel.
Old Apr 29, 2007 | 06:16 PM
spudsterier
if no one has one then im gonna just get a new one from the dealership.....i dont know how much the knuckle will cost, but i know the bolt is about $17.00[&:]
i just dont wanna go through all this crap again at a junk yard to get one off, so i would rather spend the small fortune to just buy a new one[:@]
Old Apr 29, 2007 | 06:23 PM
Captain Squalus's Avatar
Captain Squalus
Where are you located?
I'm in sw FL and have the machinery and equipment to get the old bolt out.
Old Apr 29, 2007 | 07:20 PM
das2123's Avatar
das2123
He's in Illinois.
Old Apr 29, 2007 | 07:44 PM
Captain Squalus
to bad
Old Apr 29, 2007 | 10:24 PM
racerx55's Avatar
racerx55
you'll run into the same problem at a junk yard, the bolts will twist off and your screwed, they all do it. what were they thinking when they designed that setup?
Old Apr 29, 2007 | 11:15 PM
rtneon67's Avatar
rtneon67
u cant drill it out and then try and easy out on it. u might have to heat it up and all though.
