Intermittent brake drag
Old Apr 29, 2007 | 10:18 PM
MaverickH1's Avatar
MaverickH1
Default Intermittent brake drag
On my '95 Highline, both of my front brakes drag... sometimes. I don't have ABS, so I'm thinking that it has to be the individual calipers. Ideally, I'd like to do an overhaul of both calipers to save $. But will an overhaul work? What kind of inspection/test could I do to verify one way or the other that a simple overhaul would work?
The left front piston boot is done for, and it drags less frequently than the right front does. I'm so tired of the burning brakes smell
Thanks in advance.
Old May 1, 2007 | 07:36 PM
MaverickH1's Avatar
MaverickH1
Default RE: Intermittent brake drag
To the top.
Old May 1, 2007 | 08:05 PM
das2123's Avatar
das2123
An overhaul should help, but why not just get some good used ones and save the time.
Old May 1, 2007 | 09:18 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
go to an auto store and just get new calipers. they arn't that much and they are a core item. if your pads are still good but glazed just take some sand paper to them to remove the shine then you should be fine.
Old May 2, 2007 | 12:15 AM
das2123's Avatar
das2123
ORIGINAL: DOHCgarrett t3
BE VERY CAREFUL if you do this...some brake pads contain ASBESTOS!!!!
Old May 2, 2007 | 05:59 AM
unclemike's Avatar
unclemike
I've noticed that Neon calipers are somewhat salty compared to my Diplomat anchors. For the price of new pads, why not replace them while you are at it. Although the new lining is asbestos free (mostly) the dust isn't good for your lungs. New rotors are fairly cheap too. I'm a firm believer of doing the job once and being done with it. While things are apart clean up the hub surface and apply a thin coat of anti-size compound, makes servicing the rotor easier.
Old May 2, 2007 | 06:30 PM
DOHCgarrett t3
http://www.autozone.com/selectedZip,.../selectZip.htmthis is for a loaded pair so it comes with new brake pads
Old May 2, 2007 | 06:38 PM
das2123's Avatar
das2123
$64.99 for new calipers and brake pads....not bad!
