play
RE: play
there should be no shaft play in the turbo....the more shaft play you have, the more miles that are on the turbo and the sooner it will have to be rebuilt....
mine has no shaft play at all....the turbine doesnt even budge
the hole ontop of the turbo is for the oil feed
the hole on the bottom is for the oil return
on the backside of the turbo:
top hole is coolant feed
bottom hole is coolant return
any other question?
any other question?
RE: play
well i found this so it not to bad of a price actually. i think ill just rebuild it anyway since it so cheap.
http://www.gpopshop.com/mitsubishikits.html
