tire sizes
Old May 3, 2007 | 04:13 PM
spudsterier's Avatar
spudsterier
Default tire sizes
ok well...
i am gonna get some drag tires for the r/t that i can put on the front of the car when i take it to the track.... now the thing is that i wanna get them for my 14's instead of the 17's....and i want them to be bfg g-force t/a drag radials....however the only sizes i can find that MIGHT fot are:
205/50-14
and
215/60-14
any idea if either of these sizes would work o.k.???
im usually pretty good at finding compatible sizes for my car, but i dont know how dragradials are
of course they also have 205/40-17's but then i would have to get 2 more srt4 rims for the car too[&:]
Old May 3, 2007 | 04:55 PM
das2123's Avatar
das2123
Default RE: tire sizes
As long as the wheel has a 40mm offset, then you are good. I have also heard that some people don't like them. Not very sticky.
Old May 4, 2007 | 01:46 AM
brute's Avatar
brute
I don't see the problem. You clearly don't care about the speedo, right?
Old May 4, 2007 | 01:49 AM
dysphagia's Avatar
dysphagia
omg dude i just read that you have a acr! i have a acr too!
Old May 4, 2007 | 10:18 AM
spudsterier
im not planning on using the drag radials for normal driving....only at the track...i plan on having another set for regular driving and just gonna throw the drags in the trunk....
if the bfg's are no good, any idea of some that are???? i really dont wanna spend a small fortune on tires that are just gonna be used a few times[&:]
Old May 4, 2007 | 08:45 PM
Leonheart17240's Avatar
Leonheart17240
go 215 wider is better.... unless you havta turn, 225 on a neon can turn out real bad
Old May 5, 2007 | 02:07 PM
flaminhampstr's Avatar
flaminhampstr
i have a ? about just tire and wheel size, what weel an tire size should i go with??
Old May 5, 2007 | 04:42 PM
das2123's Avatar
das2123
ORIGINAL: flaminhampstr
For everyday driving a 15" wheel is the best for handling.
