how much for head gasket?
Old May 6, 2007 | 03:41 AM
neoncrazy101's Avatar
neoncrazy101
Default how much for head gasket?
how much would it cost to do a head gasket yourself? aka how much are the head gaskets?
Old May 6, 2007 | 11:30 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: how much for head gasket?
on e bay i see them for about 40 bucks but i dont know if they are the MLS ones. and depending on the milage you should do a water pump and timing belt while you have it apart so all together about 200 max ohh and i Forgot you must replace the head bolts if you remove the head and they must be torqued down in a pattern when reinstalling
Old May 6, 2007 | 06:18 PM
das2123's Avatar
das2123
ORIGINAL: neoncrazy101
You want a HG kit, that will include the intake and exhaust gaskets as well. Modern has the Mopar one for about $85.
