oil in coolant/head gasket question.
Old May 6, 2007 | 07:46 PM
neoncrazy101's Avatar
neoncrazy101
Default oil in coolant/head gasket question.
ok well i went to see a Neon and the coolant diff. has chocolete milk in it. even a little over filled. but the car started right up, no smoke at all. idled great and sounded great. but how would oil be getting into the coolant? the motor oil looks fine. but the coolant doesn't and as i said it doesn't smoke. so could it be a head gasket or something else?
Old May 6, 2007 | 08:58 PM
neisg1's Avatar
neisg1
Default RE: oil in coolant/head gasket question.
If there is oil in the coolant it’s probably either a head gasket or a cracked head.
Old May 7, 2007 | 12:58 PM
das2123's Avatar
das2123
Was it thicker than coolant? It could be rusty water....bad radiator.
Old May 7, 2007 | 04:28 PM
neoncrazy101
WAY thicker.
Old May 7, 2007 | 04:32 PM
das2123's Avatar
das2123
Oil level?
Old May 7, 2007 | 04:34 PM
neoncrazy101
it was fine.
Old May 7, 2007 | 05:03 PM
das2123's Avatar
das2123
Maybe try a flush and see what happens.
