tach
Old Nov 5, 2012 | 07:49 PM
civichater83's Avatar
civichater83
Yup all the wires are hooked up. Turns out that there is no voltage on the signal wire behind the gauge cluster. What should I do?
Old Nov 5, 2012 | 07:50 PM
civichater83
Also its the gray/light blue wire im tapping into right?
Old Nov 5, 2012 | 08:06 PM
I_Ride_Neon's Avatar
I_Ride_Neon
The wire will only have signal if the car is running. Yes The wire color is correct. There may be more then one, I am not sure.
Old Nov 5, 2012 | 08:10 PM
I_Ride_Neon
I think you can also run the signal from the center wire on the coil, but I am not 100% on that.
Old Nov 5, 2012 | 11:49 PM
civichater83
Alright I'll test things out. Thanks guys ill let you know how it goes.
Old Nov 27, 2012 | 02:14 PM
civichater83
Just tried it out today and still doesn't work. I pretty confused.
Old Nov 27, 2012 | 06:07 PM
civichater83
I got it to get a signal with the gray/light blue wire works fine up to 2500rpm then the readings are off. Any idea why?
Old Nov 10, 2013 | 03:37 AM
clutchmafia94's Avatar
clutchmafia94
Default i have no stock tach.
I've bought a sunpro 5" tach and hooked it up but I didn't knowwhat wire to hook the signal wire to bc I have no stock cluster tach, the tach lit up bu just had no signal to any wire that I tried. anybody know how to do that?
Old Nov 10, 2013 | 07:08 AM
blk99neon's Avatar
blk99neon
You should have a green wire behind the cluster that It should go to but if not your gonna have to run it to the coil pack. I had the same problem and I got a weird reading from the coil so I then found out bout the green wire behind the cluster and it worked fine
Old Nov 10, 2013 | 11:57 AM
civichater83
its the gray/light blue wire behind your cluster. thats the one you want. if you hook it up straight to the coil pack you will only get half the rpm reading. there are two different connections behind your cluster, it would be in the pile of wires in the right connecter. splice into it and put some solder and your good to go.
