my first car need advice
Old May 9, 2007 | 01:14 AM
flacoz_da_king's Avatar
flacoz_da_king
Default my first car need advice
i need advice on how to hook up my neon its stock mostly but im new to this stuff open for ideas
Old May 9, 2007 | 05:31 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: my first car need advice
there is another post just like this!
but i'll post in this one just for you
usually people start out with the cheap stuff
since you have an automatic if you want speed then swap in a manual transmission
your throttle body is 52mm and the manual ones are 49mm (if i'm wrong sorry..hahaha)
but while you're doing that you can get a cold air intake
don't go with those AEM intakes that place the filter over the header because it's just sucking up hot air
you can make a cold air intake (just go to the search box and type in "3.0 cai")
to make it it's about $50 at the most
while the ice man/mopar cold air intake from summit racing is $300
if you have a single over head cam then you should get a different muffler
the exhaust piping is arleady 2 1/4 so just look for either a dual over head cam or an aftermarket muffler
you can also go ahead and get another exhaust header (best for SOHC are the pacesetter headers)
if you have a DOHC and you have to pass smog just get a mid-length header so you can keep the cat
other than that people have talking about getting different motor mounts to help
and if you want a lower/stiffer ride it's best to get the KYB GR2 struts with either Mopar high rate springs (if you can find them) or Skunk 2s
Skunk 2 makes adjustable springs but they are obviously more expensive
also another cheaper mod is an underdrive pulley
if you dont know what it is it's a smaller and lighter crank pulley that helps the car rev faster
you can also get a Mopar ECU which is an easy upgrade
just plug it in and you get 8-11 wheel horsepower
sorry if i missed some
you can find most if not all of these parts at www.modernperformance.com
Old Jul 29, 2007 | 12:04 AM
flacoz_da_king
thnx
Old Jul 29, 2007 | 11:42 AM
Dr_KY's Avatar
Dr_KY
You should save all yourmoney and continue to read and ask plenty of questions for a few more months. Find out what works and what dosen't then decide what direction you and you car wants to go.
Old Jul 29, 2007 | 02:11 PM
95neonriceeater
holy crap
it took 2 months to say thanks?!
hahah atleast you actually said thank you...
and with the money you'll be dumping into the engine for bolt ons you'll notice later on that you'll want even more power
