first time neon owner
Old May 9, 2007 | 01:21 AM
tandc972003's Avatar
tandc972003
Default first time neon owner
I have a 96 neon sohc never had a 4 banger before would like to do some stuff to it to make it a little more fun to drive more speed better handling I got this car to see if I would like compact cars but never realy worked on one before where is a good place to start
Old May 9, 2007 | 01:26 AM
flacoz_da_king's Avatar
flacoz_da_king
Default RE: first time neon owner
i just got my neon also ,the specialist said to start with the air intake system
Old May 9, 2007 | 01:29 AM
spudsterier's Avatar
spudsterier
a good cold air intake such as an iceman style intake
underdrive pulley
motor mount inserts
exhaust
just to start
Old May 9, 2007 | 01:41 AM
neoncrazy101's Avatar
neoncrazy101
not a mod. but make sure it has the MLS head gasket.
tandc972003
I have put a cold air intake on it but I dont see how it helps the damn thing gets the air from the back of the motor its all hot air Ive put on a new cat new o2s plug wires timing belt crank sensor cam sensor I would like to find a head and cam for itbut parts seam to be hard to find for this car
Old May 9, 2007 | 01:46 AM
neoncrazy101
thats a WAI. you can find an old ice man that goes through the front, or go to Summit racing and find the mopar CAI but its like $300. OR you could go with the cheap one at $30-50 which is the 3.0L CAI. (homemade)
Old May 9, 2007 | 02:01 AM
tandc972003
how do the sohc neon respond to puting a hood scoop on it and making it force feed cooler air into the throtle body
Old May 9, 2007 | 05:12 AM
95neonriceeater's Avatar
95neonriceeater
with no air filter on it?!
YOU CRAZY!
Old May 9, 2007 | 11:52 AM
das2123's Avatar
das2123
ORIGINAL: tandc972003
Not enough to notice any difference. Look at this thread for more info...
https://dodgeforum.com/m_298810/tm.htm
And then read through the 1st Gen FAQ's up top.
Old May 9, 2007 | 10:20 PM
tandc972003
fab up under the hood scoop to put a Edelbrock Pro-Flo Air Cleaner thats what I had on my camaro
