struts
Old May 13, 2007 | 03:57 PM
95neonriceeater's Avatar
95neonriceeater
Default struts
so my friends and i were talking last night and his dad said that KYB struts weren't that great
so i was looking on ebay for cheap konis and the lowest for 1st gen are 800
but the lowest for 2nd gen is 500
could we put 2nd gen struts on a 1st gen?
Old May 13, 2007 | 04:26 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: struts
2 gen wont work
Old May 13, 2007 | 04:34 PM
95neonriceeater
Default RE: struts
damn them!!!!
alright without starting a new post
with the ACR konis
i know that they were black stock (didn't some come yellow?)
but do they say koni on them?
because when i found hte ACR at hte junkyard i didnt see koni on it
i saw "chrysler"
hmm...
Old May 13, 2007 | 04:45 PM
95to96transplantneon's Avatar
Default RE: struts
Ok the shaft on them are black the rubber boot on the top are yellow. You will see the Chrysler 5 star symbol and it will say made by koni eather to the side or under the 5 star sign, can't remember. Compleatly worth the 800 by the way. I lucked out. But if I dident have them and acually had 800 I would buy them. lol. Back to the springs. I also have the KYB lowering springs and I love them to death. The spring rate isent so stiff that you slam around they have some bounce to them but they provide a good launch. I have had mine in for about 15000 miles and over stock there heaven. They also lower the car to a good stance not so low that the tire well looks weird because it lowers the car to much and not to high that it doesent look like you did anything. God I need to get pics of my car. lol lazy though. I'll get some today. And throw them up. maybe even get you a pic of those shocks.
Old May 14, 2007 | 12:34 AM
spudsterier's Avatar
spudsterier
Default RE: struts
i have the acr konis on my r/t.....they are black, the yellow ones were the aftermarket konis....but my acr'shave the koni sticker on the back side of them towards the bottom......you can always tell konis because if you pop the hood and look at the top of the struts, you will see a small nipple sticking up so you can put the adjuster ***** on them...(looks kinda like the tip of a flat head screw driver)
i like my yellow ones more since they stand out.....its too bad one of the blew[:@]
Old May 14, 2007 | 01:13 AM
95neonriceeater
Default RE: struts
thanks guys!
i was looking on eBay
http://cgi.ebay.com/ebaymotors/KYB-G...spagenameZWDVW
are those good?
i would assume they came with kyb springs...guess not!
Old May 14, 2007 | 09:39 AM
spudsterier
Default RE: struts
hopefully thats not the pic of what you would get[&:]
Old May 14, 2007 | 12:05 PM
das2123's Avatar
das2123
Default RE: struts
ORIGINAL: 95neonriceeater
Your friend's Dad is wrong. They are great on the 1st gen neon.
but the lowest for 2nd gen is 500...could we put 2nd gen struts on a 1st gen?
You could, but then your neon would sit higher. 2nd gen owners can use stock 1st gen springs to lower their car a bit.
Old May 14, 2007 | 12:31 PM
DOHCgarrett t3
Default RE: struts
i dont know for some reason i had a second get strut on my 1st gen and it bolted up but hit the tire when i tried to mount it?
Old May 14, 2007 | 01:30 PM
das2123's Avatar
das2123
Default RE: struts
ORIGINAL: DOHCgarrett t3
Ahhh, I was thinking of the springs, not the strut. You are correct.
