Help finish my swap!
Old May 14, 2007 | 02:49 AM
NEONRT98's Avatar
NEONRT98
Default Help finish my swap!
Some of the things I have that need to go:
From the First Gen:
Complete steering column from steering wheel to steering collar on R&P, Cruise Control- SOLD
Headlight/Interior light switch- $10
HVAC control unit- $5
Passenger side air bag- undeployed - $75
Driver side dash peice w/ vents - $5
Passenger side dash peice w/ vents - SOLD
Glove box- $5
Lower shield to steering column- Plastic- $5
Rear defroster/Fog light switches- $10
Neon R/T Rims w/ Tires - Make me an offer I can't refuse - Local pickup prefered
98 DOHC complete w/ cams and gears- $150
Aluminum intake manifold (red) - $40
Valve Cover- $15
Chrome fuel rail - $30
Front mount polyurethane inserts (Used) - $10
ATX TB w/ sensors- $40
Top dash peice w/ bezel- $20
From SRT-4
ABS Module - $75
Defrost switch - $5
Interior Wiring Harness w/ Kicker Option- $200 (Price Lowered)
2 front and 2 rear stock struts w/ springs 23k miles- $175
Other
FPR (Never used) - $50
I have other odds and ends too, if you need something drop me a line and I will see what I can do!!
This stuff needs to go ASAP!! I need to finish my swap!!
Old May 14, 2007 | 03:11 AM
mmench's Avatar
mmench
Default RE: Help finish my swap!
wat kind of fpr regulator is it?
Old May 14, 2007 | 03:17 AM
NEONRT98's Avatar
NEONRT98
Like This One (Chrome w/ gauge)
And thats the wrong price too, meant $40...
Old May 14, 2007 | 04:37 AM
95neonriceeater's Avatar
95neonriceeater
if only the struts fit 1st gens...
WHERE THE GUY WITH THE BROKEN SRT4?!?!?!
HE MIGHT NEED SOME PARTS!
Old May 14, 2007 | 09:47 AM
spudsterier's Avatar
spudsterier
damn....too bad its far away...you should of let me know when you passed through and i would of atleast taken the rims off your hands for a good price
i want the motor and the rims[:@]
Old May 14, 2007 | 11:43 AM
NEONRT98's Avatar
NEONRT98
You cant have the motor :-P
As for the rims.. I didnt know I wanted to get rid of them up til this weekend... Want me to check on shipping prices, Spud?
Old May 14, 2007 | 12:28 PM
das2123's Avatar
das2123
ORIGINAL: NEONRT98
For 2 rims with tires, shipping will be around $50. Just to let you know. The rim alone weighs about 16 lbs and could be put in a 16x16x10 box.
Old May 15, 2007 | 12:36 AM
spudsterier
i will have to check my funding[&:]
Old May 15, 2007 | 11:29 AM
das2123's Avatar
das2123
ORIGINAL: NEONRT98
$10 shipped?
Old May 15, 2007 | 11:48 AM
NEONRT98's Avatar
NEONRT98
ORIGINAL: das2123
ORIGINAL: NEONRT98
$10 shipped?
Sure, the shipping wouldnt be too much for it. Is it for the 98 I assume?
