Old Aug 10, 2015, 05:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
How to turn off Check Engine light?
Old May 15, 2007 | 02:05 AM
billie5769's Avatar
billie5769
Default How to turn off Check Engine light?
Anyone know how to turn off the check engine light on a 96 neon? i tried disconnecting the battery, didn't work. On my honda you remove a fuse and that turns the light off. I dont know how it works on a 96 neon
Old May 16, 2007 | 02:40 PM
das2123's Avatar
das2123
Default RE: How to turn off Check Engine light?
Disconnecting the battery or removing the fuel pump fuse (20a) for about 10-15 minutes will reset the PCM.
Did you fix the problem? If not, the CEL will light up again.
