Trouble code #42
Old May 19, 2007 | 10:06 PM
harwelldav's Avatar
harwelldav
Default Trouble code #42
I was wandering what are some of the possible problems assiciated with this code? and well what are some of the fixes?? is it the fuel pump or is it something else?
thanks for all your help...
dave
Old May 20, 2007 | 02:57 AM
das2123's Avatar
das2123
Default RE: Trouble code #42
Code 42 - Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles.
Check your relays first.
Old May 20, 2007 | 08:42 PM
harwelldav's Avatar
harwelldav
I have checked them but i'm not fully sure how to check for a bad relay?
Old May 21, 2007 | 01:52 AM
das2123's Avatar
das2123
ORIGINAL: harwelldav
If your horn works, swap the relays and check to see if they work. Swap the ASD or fuel pump relay into the horn spot and see if your horn still works.
