DOHC to SOHC
Old May 20, 2007 | 02:53 AM
racerx55's Avatar
racerx55
Default DOHC to SOHC
im planning on building this next motor, DOHC bottom SOHC head with 95 cam, which PCM should i use???? id like to use the DOHC PCM to get the 7250 rev limit since i use it alot and need the high RPM.
guess i might have to try both and see which works better.
anyone know if the wire harness will work? remember its arace car, i just need the basics hooked up for it to run and i can rewire whatever. should i use my aluminum SOHC intake or the plastic one?
i just figured i could get some input on it before i do it.
Old May 20, 2007 | 03:01 AM
das2123's Avatar
das2123
Default RE: DOHC to SOHC
You can use the DOHC PCM, might run a little rich but probably doesn't matter to you. Plastic intake is lighter so I'd use that unless you are wanting to modify the aluminum one. Harness will work fine.
95neonriceeater's Avatar
95neonriceeater
the plastic one weights less
Old May 20, 2007 | 03:02 AM
racerx55's Avatar
racerx55
i need it to run rich, with the exhaust the way i have it the o2 temps are too cold and the computer leans it out anyway
Old May 20, 2007 | 03:03 AM
racerx55's Avatar
racerx55
im looking to lose alot of weight , gain compression and power from it, and the biggest gain i need is TORQUE , something the DOHC cant find no matter what i do.
Old Mar 19, 2008 | 07:57 AM
Ghost Neon 2's Avatar
Ghost Neon 2
2.4....
