stupid heat sheild
Old May 21, 2007 | 02:42 AM
neoncrazy101's Avatar
neoncrazy101
Default stupid heat sheild
i hate the stupid heat shield on the exhaust manifold. how in the world do u get it off? it has 2 bolts on both sides and one is under the PS res. do u have to take off the res. to get that bolt off? and if so, how do you go about taking it off?
Old May 21, 2007 | 06:04 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: stupid heat sheild
I used tin snips to get mine off since it was rusted I just pried it open a bit after i took out the old air box i had plenty of room then i used some green handled and red handled tin snips to finish it off. green handles cut left red handles cut right yellow is for straight cuts
Old May 21, 2007 | 10:19 AM
spudsterier's Avatar
spudsterier
i used tin snips too
but once and a while i have a problem reaching some of the spots....so i use a dremel
Old May 21, 2007 | 06:22 PM
streetbikr600's Avatar
streetbikr600
i kept mine on because i have headers and i pass the visual for smog
Old May 21, 2007 | 10:14 PM
dcmcguy's Avatar
dcmcguy
when i put my head gasket in i just ripped off the shield with a vice grip......the boltd were extremely rusty
Old May 21, 2007 | 11:08 PM
DOHCgarrett t3
i used to do heating and cooling so i know the ways to cut in tight spots with my snips lol
Old May 22, 2007 | 01:19 AM
spudsterier
i just deliver papers, so i have to improvise alot
Old May 22, 2007 | 12:50 PM
jmatthews's Avatar
jmatthews
I took off my head with the exhaust mani still on, then the heat shield came off easy. I'm getting ready to put it back on, Should I leave it off? makes it easier to add headers later.
Old May 22, 2007 | 01:19 PM
neoncrazy101
so i should just cut it off... ^^ can i leave it off? or can it cause damage to other parts...such as the PS Res.?
is it bad to take the head off with the manifold still on? and then taking the manifold off?
Old May 22, 2007 | 02:36 PM
spudsterier
ORIGINAL: neoncrazy101
so i should just cut it off...can i leave it off? or can it cause damage to other parts...such as the PS Res.?
i have never noticed any damage to any other parts when its been removed......and you can just leave it off if you want too.....the stock manifold get hot, but not super hot....
when i put the turbo on my car i didnt have the heatshield for it.......after a while the coolant over flow tank became nice and warped.....but a turbo gets alot hotter then a stock manifold
no, it wont cause you any problems to take the manifold off with the head
