stupid crank pulley
Old Jun 5, 2007 | 07:31 PM
racerx55's Avatar
racerx55
Default RE: stupid crank pulley
i was just gonna say the same thing
Old Jun 5, 2007 | 07:46 PM
srt4sleeper's Avatar
srt4sleeper
ive had the EXACT same problem with those stupid autozone rent-a-tools. i just put a smallbold that would fit where the rod was insertedin the puller and put the longest rod from the kit over that. then hopefully the person that used it after me would never have the same problem. just dont tell them you did that when you return the toll, what they dont know wont hurt them
Old Jun 5, 2007 | 08:32 PM
streetbikr600's Avatar
streetbikr600
i use the one from my tool vender at work..its a snap on for like $100 it works great. i wrok at firstone so i use it all the time and it works great
Old Jun 5, 2007 | 08:42 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
i just bought one from snap on and i got 3 diffrent rod legnths worked great and i plan on using it again on other neons
Old Jun 6, 2007 | 01:16 AM
spudsterier's Avatar
spudsterier
i use my snap-on blue point all the time....got it used from ebay for $60
Old Jun 6, 2007 | 02:05 PM
rjab0196's Avatar
rjab0196
Ok So . I bought a 99 Neon R/T .. I am fixing it up. I rented a 3 jawed puller from Advanced( looked exactly like the one in the Chilton Manual) I did exactly what it said in the book and it broke the pully.... So now how do I get it off.. I can't attach a pully unless it attahes to the outside or the outside ring on the inside if that makes sense.. But I couldn't get to catch on there it just sliped off... I plan on buying a Unorthodox pulley anyway so I don't really care that it is broken.. I just need it off.... Thanks
Old Jun 6, 2007 | 02:24 PM
prplhaze's Avatar
prplhaze
Mac tools, and I think snap-on, make a special puller for the neon engine.It cost me about $100. I tried the pullers from autozone first and had nothing but problems.Once you use the the mac tool, you will see how easy it is.You can try a dealer, and maybe a friendly mechanic will loan you his tool. In my opinion, Dodge made the pulley so fin hard to get off and on, so that a regular person would have a heck of a time and have to take it in to the dealer to get it fixed. So they make more money on repairs.
Old Jun 6, 2007 | 04:00 PM
mathias's Avatar
mathias
ORIGINAL: rjab0196
If you attached the puller to the outside of that pulley, I'd imagine you would break it. So, if it's just the outer portion that's broke you can still get it off easily. The puller should be connected to the pulley on the innermost portion that is connected to the crankshaft. If you feel around the backside of the this innermost portion you'll feel little slots or grooves on the backside for the puller to lock into. The puller I use is from NAPA. It's a combination puller and costs $15. It's a combination puller (8 ways I think.) but set it up just like they show in the picture and the jaws will fit the slots on the back of that crank pulley perfectly.
Now, if you've broken the pulley to the point you cannot attach the puller to the inner portion (I don't think you did that though.), then you best get a cold chisel, sawsall or cutting torch and be real careful!
http://www.napaonline.com/NOLViewer/...amp;ShowPics=1
Old Jun 7, 2007 | 01:08 AM
DOHCgarrett t3
http://s165.photobucket.com/albums/u...t=IMG_0441.jpgthis is exactly what you need. as you can see from the picture it comes with 3 rods if you rent it from auto zone dont walk out of there without all 3 rods. http://buy1.snapon.com/catalog/objec...9700/49607.JPGfor a picture directly from the snap on website
Old Jun 7, 2007 | 04:56 AM
rjab0196's Avatar
rjab0196
Yes I attached the first puller to the inner most point... and it broke.. so I will try the other pullers you all have mentiond but i dont think i will be able to attach it since it is now broken...
Does anyone think the orthodox pulley is a good idea or do you know of a diff one that is as good o better that is cheaper????
Thanks
