engine rebuild help
Old May 24, 2007 | 05:38 PM
pssssst's Avatar
pssssst
Default engine rebuild help
hey every1, im going to be rebuilding my motor with all high end rebuild parts from modern performance for the sohc turbo setup. i just have a few questions before dedicating myself to it... when i rebuild the engine with all the new internals, will i be able to upgrade the crank pulley as if it were a stock engine? will i need a new comp? what other things will i need other than the top and bottom end rebuild kit? i know i need a lot of other things for the turbo which i have already researched but im jw as far as the motor goes... thanks for the help
Old May 24, 2007 | 07:10 PM
das2123's Avatar
das2123
Default RE: engine rebuild help
Rebuilding the top and bottom end will be most of it. You will want to get the block bored and balanced also.
Old May 24, 2007 | 07:45 PM
spudsterier's Avatar
spudsterier
you can use an underdrive pulley and you can use your stock pcm
