fuel
Old May 24, 2007 | 11:50 PM
mmench's Avatar
mmench
Default fuel
will srt4 injectors fit on a first gen? or do i gota change the harness and if so how n wat do i need
Old May 25, 2007 | 10:55 AM
spudsterier's Avatar
spudsterier
Default RE: fuel
physically they will fit...but i do think you will need the plugs from an srt4 as well.....but you might be able to find the plugs from a regular 2nd gen, or try autozone and see if they have universal plugs
Old May 25, 2007 | 12:24 PM
das2123's Avatar
das2123
Default RE: fuel
ORIGINAL: mmench
Unless you have a turbo, you don't need them.
Old May 25, 2007 | 03:31 PM
mmench's Avatar
mmench
Default RE: fuel
well i am turboing my car within the next month or so
Old May 25, 2007 | 03:50 PM
das2123's Avatar
das2123
Default RE: fuel
ORIGINAL: mmench
I see, thats why you are selling the Iceman intake.
Why not just get some Accel 24 lb injectors or are you doing a budget build?
To get the SRT injectors to work, I have "heard" that you need to mod the fuel rail. I dont know what that means though.
Old May 25, 2007 | 04:03 PM
spudsterier
Default RE: fuel
as far as i knew they fit right in.....but only modding i can think that could possibly need to be done is sumthing alon the lines of boring out the ports a bit, maybe the injector tops are a larger diameter...or maybe the injectors are too long/short and you need to find a way to change the bracket that mounts the rail to the manifold....i ono
Old May 27, 2007 | 07:42 PM
mmench's Avatar
mmench
Default RE: fuel
well i got my intercooler, forge bov, another turbo and manifold (makes 3 manifolds now and 2 turbos) and srt injectors. i un plugged the harness to my injectors to see if the srt ones would fit the wiring and it seems to hook rite up. as far as fitment to the intake and fuel rail i havent tried yet but hope to do it sooon... nd if anybody needs or want a srt4 stock turbo and manifold i got em so i'll sell em to ya
Old May 27, 2007 | 07:52 PM
neonracer1010's Avatar
neonracer1010
Default RE: fuel
how much
Old May 28, 2007 | 12:54 AM
spudsterier
Default RE: fuel
ORIGINAL: neonracer1010
how much
you planning on getting one for your car????
Old May 28, 2007 | 04:13 PM
mmench's Avatar
mmench
Default RE: fuel
how much for wich part
