junkyard search ends with disappointment
Old May 25, 2007 | 05:35 AM
kris95neonspt's Avatar
kris95neonspt
Default junkyard search ends with disappointment
I have been searching for a stock 95 pcm and wireing harnessfor a 95 neon dohc mtx and have had no luck. Only pcmi found was for a 95 sohc mtx witch i don't think will work right? I am not in a big hurry to get one but would like to have it so i don't have to keep search for one. Anywayif the sohc mtx pcm won't work does anyone have a 95 dohc mtx and wireing harness they would sell if so how much also i have a 95 dohc atx pcm and was tould it had a lower rev limiter on it is this true?
Old May 25, 2007 | 06:17 AM
racerx55's Avatar
racerx55
Default RE: junkyard search ends with disappointment
atx pcmwill work, but you will never have a steady idle, and it will probly stall constantly.
makes it a pain to drive in trafiic. ive done it on 3 or 4 cars that we race & they run good wide open but always wanna stall after you let off the gas, they wont ever find a good idle., and your rev limit is only 6750, Vs 7250.
plus you have to hook the clutch switch to the neutral switch or it'll have a rev limit of 5800 (PCM is thinking an auto in park/neutral)
