Plymouth Neon Rotten Rear Brake Lines
I see there's been a recall on 1995 Dodge Neon's for early corrosive REAR brake lines. Does anyone know when these recalls expired? Will a Plymouth still honor that recall?
My grandmothers 95 Neon lines are completely rotten and need replacement. I did a search and saw the recommendation of getting them from AutoZone etc. Is their an easy way to route them, as they appear to be difficult to route the original way. Also, any tricks to beware of?
it should still cover it, as long as u point it out that it was a recal. but you also might want to see if the Neon already had the re-call done to it, cause if it already had it done then they might not honor it.
