NEED HELP ON THROWOUT BEARING ASAP
the clips on the throwout bearing are they imporntant to have on there cuz i was just putting it in and they broke off. i need to know if it will affect anything with them being broken off.
the clips on the tob hold it in place on the fork.....if there is a little play in the fork movement, then the bearing will just kind float around on the shaft
did you get the tranny together then???
