SRT-4 swap??????????
Old May 30, 2007 | 04:06 PM
  #21
spudsterier's Avatar
spudsterier
Default RE: SRT-4 swap??????????
if you want it going fast then i would stay away from the srt4 swap......just my opinion though
Old May 30, 2007 | 04:12 PM
  #22
estneon's Avatar
estneon
i agree its not realy a faster engine i do have some proof my non turbo neon 2.0 can take my non turbo stratus 2.4 so it isn't that muchfaster but i think my strat could take it if it was a mtx
Old May 31, 2007 | 03:42 PM
  #23
iwantansrt4's Avatar
iwantansrt4
What would I need to do in order to put a trubo on my 2.0 DOHC and not have to worry about blowing it? Will I need to bore the pistons, put new rings, etc? it does blow smoke if it idols for a minute and you rev it up.
Old May 31, 2007 | 03:56 PM
  #24
96expresso's Avatar
96expresso
Well, a couple post down someone mentioned that if you get a srt-4 manifold, and turbo, it will bolt right on to your neon. Because your car is already smoking though, i would say you probally need to do some work to the engine. You could probally do a stock rebuild for pretty cheap and be able to run 6-10psi safely. If you wanted more power i would say build up the bottom of the motor with some forged parts. Although i guess if you are blowing white smoke, you could probally just replace the gaskets on the top of the block. What i am trying to say is: get your car running great first, then turbo it.
Old May 31, 2007 | 04:21 PM
  #25
spudsterier
these would help you out alot....but be prepared to spend alot of money really fast
i wouldnt trust more then about 8psi on a stock bottom end.....the rods arent that strong...and with the milage on the motor you might have a problem with the bearings like i did....
if you want to put the srt4 turbo on your car and be able to run as much boost as you want and not worry about anything, then it wil ost a pretty good chunk of change....i think ive got about 5k in my motor right now.....but that has a few extra parts too
[IMG]local://upfiles/29901/2B952EEB048D46A08BEA2EE3B900CB8D.jpg[/IMG]
