question about fusable link
Old May 30, 2007 | 07:23 AM
tthus111's Avatar
tthus111
Default question about fusable link
if the fusible link burnt up would that kill all power to the whole car. Meaning no power to starter, all lights, brake lights, dash lights,radio. i mean complete loss of all power. by the way its a 97 sohc with 170,000 miles. checked battery( tested at autozone) pos and neg cables look good, grounds seem ok. atleast the ones i can see. checked fusesin black box behind battery and theones inside car by drivers side door.or could i have blown power distribution box behind battery?
Old May 30, 2007 | 07:37 AM
tthus111's Avatar
tthus111
Default RE: question about fusable link
and while im at it can anyone tell me where the fusable link runs. i read it connects to the starter or seliniod and runs to the alternator. is that correct? does it run in front of the engine to alternator orwrap around behind engine?
Old May 30, 2007 | 11:42 AM
das2123's Avatar
das2123
It's a black wire that connects to the starter. The link being burnt out wouldn't kill all power, but it might not let the car start up.
Old May 30, 2007 | 12:52 PM
tthus111's Avatar
tthus111
thanks for the response im looking for something that would kill all power to neon. no headlights brake lights, interior lights, no starting or cranking of the engine. had battery tested at autozone, its good. fuses in pdc good, fuses in drivers side panel good. battery cables ok (pulled them off posts and used steel wire brush to clean them.) visible grounds look good. but couldnt find fusible link from starter to alternator. the only evidence of power i see is when i turn key fuel gauge needle climbs or moves. any ideas?
Old May 30, 2007 | 12:59 PM
das2123's Avatar
das2123
Have you tried jumping it?
Old May 30, 2007 | 02:00 PM
tthus111's Avatar
tthus111
if it wont start with good battery how will jump starting be any different?( i only ask becaause that doesnt make sense to me.) does jumpstarting allow more current to flow.
Old May 30, 2007 | 02:44 PM
das2123's Avatar
das2123
To retest the battery. If not, then you are gonna have to look at all your connections and grounds. You might also want to pull the battery tray out and see if there are any corroded wires under the PDC.
Old Jun 1, 2007 | 10:04 AM
tthus111's Avatar
tthus111
was rechecking grounds with flash lite in dark and turned headlights on (dont work though) to see if i moved some wire and got power to them. and i ran my hand across positive battery post and the dam thing was flaming hot. so im assuming its might be ground on neg side?
Old Jun 1, 2007 | 12:21 PM
das2123's Avatar
das2123
Check the negative grounds.
