Want more Power From a SOHC '96 Neon
Old May 30, 2007 | 02:32 PM
neon9's Avatar
neon9
Default Want more Power From a SOHC '96 Neon
I have a '96 DodgeNeon SOHCthat has an MSD coil pack, MSD spark plug wires, K&N cold air intake,and a5 speed transimssion. It alsohas Magma Flowexhaust system with no catalytic converter.Looking to get more powerinexpensively. Does anybody have any suggestions of thingsthat I can do?
Old May 30, 2007 | 02:36 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Want more Power From a SOHC '96 Neon
underdrive pully... switch SOHC exhaust to DOHC exhaust, PCM, and screw the K and N intake and get an Iceman intake
Old May 30, 2007 | 02:41 PM
neon9's Avatar
neon9
What do you mean by switch the SOHCexhaust to DOHC exhaust? Do you mean changingthe manifold or something else?
Old May 30, 2007 | 03:29 PM
95neonriceeater's Avatar
95neonriceeater
he means
change the mufflers
but don't since you already have a magna flow
you would have gotten the same power output with the DOHC muffler as the magna flow
so just stick with your magna flow
and is your K&N intake the 3.0L or one of the eBay ones that sits above the exhaust manifold?
you can also go to a junkyard and take the throttle body off of an automatic neon
the automatic neon's throttle body is 52mm compared to your mtx throttle body that is 49mm
Old May 30, 2007 | 08:15 PM
das2123's Avatar
das2123
ORIGINAL: neon9
Only the exhaust helped you power wise. Look for a real CAI or make your own 3.0L CAI, a UDP, an ATX TB to get you started. From there you will have to look at a header, post/polish the head, cams and so on.
Old May 30, 2007 | 08:36 PM
DOHCgarrett t3
ohh err wasint paying attetion when he said magma flow and i was give a generic answer
