Turbo Setup
Old May 31, 2007 | 02:08 AM
dcmcguy's Avatar
dcmcguy
Default Turbo Setup
I'm looking to turbo my 96 sohc since it's not my daily driver anymore...and I was wondering what type of turbo I should use? I've read around a little and a garret t3 supposedly works good on a neon??? I was also wondering, is there like, an older car i would find in a junkyard that would have a turbo i could use for my sohc that i could rebuild or something. Any input would be awesome! Thanks
Old May 31, 2007 | 02:22 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: Turbo Setup
you can get a DOHC head and put an SRT4 manifold and turbo
or get a Hahn turbo kit
Old May 31, 2007 | 06:13 AM
carguy1998's Avatar
carguy1998
so the srt4 turbo manifold will fit on the 1st gen neon and will be a direct bolt on with no modification? is that right?
Old May 31, 2007 | 06:19 AM
95neonriceeater
the turbo manifold will bolt right onto the exhaust side of the DOHC
spud has done it so just ask him about it
Old May 31, 2007 | 06:31 AM
carguy1998's Avatar
carguy1998
hey, is spud his full name, cause i couldn't find him?
Old May 31, 2007 | 11:21 AM
spudsterier's Avatar
spudsterier
ORIGINAL: carguy1998
email replied too
Old May 31, 2007 | 08:05 PM
dcmcguy's Avatar
dcmcguy
Ok, BUT i want to know if there is an old car i can get a turbo off of that will work in my sohc
Old May 31, 2007 | 08:18 PM
mmench's Avatar
mmench
if u switch to a dohc and want to do the rt4 turbo setup i have an extra one layin around
Old May 31, 2007 | 10:38 PM
dcmcguy's Avatar
dcmcguy
what do you have an extra of? Also, im going to the junkyard saturday so it would be great if i knew what carsto look for a turbo that will fit an sohc neon. I'm planning on spending LESS than $500
Old May 31, 2007 | 11:52 PM
spudsterier
you can find alot of turbos that will work.....but not bolt right on
