turbo neon AWD
Old Jun 1, 2007 | 08:06 PM
thefamilyguy209's Avatar
thefamilyguy209
Default turbo neon AWD
Is it possible to bolt up the 5 speed awd tranny from a plymouth laser/talon 2.0 to our 420a engine?
Old Jun 1, 2007 | 09:05 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: turbo neon AWD
the neon engine isn't the mitsubishi 420a engine
Old Jun 1, 2007 | 09:24 PM
GrApHite03's Avatar
GrApHite03
He's right...
Chrysler Engine code: 2.0L DOHC = ECC
Chrysler Engine code: 2.0L SOHC = ECB
Chrysler Engine code: 2.0L SOHC Magnum = ECH
Chrysler Engine code: 2.4L DOHC N/A = EDZ
Chrysler Engine code: 2.4L DOHC Turbo = EDV/EDT
and actually... The AWD models of all DSM's only came with the 4g63 which is an totally different motor. The AWD tranny from 4g63 won't bolt up to a 420a or any neon motor.
k3v
Old Jun 2, 2007 | 12:54 AM
das2123's Avatar
das2123
NO!
Old Jun 2, 2007 | 01:47 AM
Dazzellerr's Avatar
Dazzellerr
ORIGINAL: das2123
NO!
someone should make an adapter plate to do this tho. that would kickass!
Old Jun 2, 2007 | 05:18 AM
racerx55's Avatar
racerx55
but you guys never noticed the transmission is on the opposite side of the car with a 4g63 Vs a 420a / ECB (which is the same bottom end)
4g63 rotates the same direction as the neon motor, but is the other way in the car, basically it spins backwards from any normal vehicle.
belive me ive already had thought of stripping my talon and fabbing it all into a neon shell.
lots and lots of work and fabricating
Old Jun 2, 2007 | 03:16 PM
Dead_In_The_Neon's Avatar
Dead_In_The_Neon
Didn't the PT Cruiser come AWD as a option? If so couldnt the tranny be used out of it? I've been wanting a AWD small vehicle project and this'll take the cake.
Old Jun 2, 2007 | 05:25 PM
das2123's Avatar
das2123
^^^With enough money, time and know-how...blah blah blah.
Old Jun 2, 2007 | 06:25 PM
spudsterier's Avatar
spudsterier
never heard of an awd pt cruiser
Old Jun 2, 2007 | 06:55 PM
BadBrads97Neon's Avatar
BadBrads97Neon
ORIGINAL: spudsterier
X2 but who knows.. anything is possible with the right amount of money, time and skills.
