weird alternator
okay... so when i start my car it will run for about 2 minutes then the battery light comes on... about 10 minutes after that the car completely loses power and stalls (dead battery)... ill let it sit for a couple hours and then it fires right up.... what the heck is goin on???
check your grounds and with the car running, check the plug that goes into the alternator.....if you wiggle the plug a bit when the car is running you can listen for the idle to change.....if it does, then thats your problem
