need help
Old Jun 5, 2007 | 06:33 PM
romeo21's Avatar
romeo21
Default need help
ok well its been a long time sence i have been on here but i am swaping a 2000 neon motor in my 96 neon what problems am i going to run into will my 96 wiring harness work and will the 96 pcm work will the tranny bolt up will the motor mount on the pasanger side fit all these questions i am hoping to get answerd any and all help will be realy helpfull thank alot
Old Jun 6, 2007 | 02:43 AM
romeo21's Avatar
romeo21
Default RE: need help
can no one help with this
Old Jun 6, 2007 | 12:41 PM
das2123's Avatar
das2123
I would think you could use your 96 wiring harness and PCM, but you may have to swap some of your old sensors into the newer motor.
Old Jun 7, 2007 | 10:12 PM
romeo21's Avatar
romeo21
will the 96 trany bolt up to the 2000 motor and the motor mount on the passanger side becuse the two mounts are not the same will the 96 mount fit on the 2000 motor and i think thats all i have for now thanks for your help
Old Jun 8, 2007 | 12:54 AM
das2123's Avatar
das2123
You would use your 96 motor mounts.
Old Jun 20, 2007 | 08:26 PM
romeo21's Avatar
romeo21
ok what parts do i need to make this swap work please help i miss my car
Old Jun 20, 2007 | 11:06 PM
das2123's Avatar
das2123
Just use the 2000 engine. Bolt all your 96 stuff to it.
Old Jun 21, 2007 | 02:29 PM
romeo21's Avatar
romeo21
thats it man i hope its just that esay what about the clutch i have a modular clutch to i have to stick with the same type or can i use a none modular
Old Jun 21, 2007 | 02:41 PM
das2123's Avatar
das2123
Stick with the modular clutch.
