more problems
Old Jun 6, 2007 | 11:26 AM
MINIHEMI's Avatar
MINIHEMI
Default more problems
seems like it never ends eh?
well i had an overheating problem to no avil the wires were rusted out...don't know how this happens but whatever
check engine light is starting to bother me codes are as follows :12, 21, & 55 took it to the mechanic he thinks it's the o2 sensor but doesn't want to replace it in case it is something else, and a little history i just got my head gasket repaired and he said anti freeze might have leaked and contaminated it.
need help
thanks for the help
MILES
P.S. i want that light to stay off, really it's getting annoying...over 3 months now
Thx
Old Jun 6, 2007 | 02:20 PM
prplhaze's Avatar
prplhaze
Default RE: more problems
So, you fixed the overheating problem? Im too lazy too look up those engine codes, If you could post what those are it would help a lot..
Old Jun 6, 2007 | 08:42 PM
das2123's Avatar
das2123
12-battery has been disconnected within the last 50 key-on cycles.
21-02 sensor problem (oxygen sensor), upstream or down stream (probably upstream sensor)
55-end of codes.
I'd check the wiring to the sensor and see if its frayed or a anything. Reset the PCM and see if it comes back.
Old Jun 6, 2007 | 10:31 PM
MINIHEMI's Avatar
MINIHEMI
i have reset the pcm via battery disconmnect at least a dozen times and the mechanic has "wiped" the pcm 3 times as well, and the light stays off for about 3-5 turn ons after the "wiped" has been done, but with me disconnecting the battery it comes on immedatly...unless any of you know a better way to wipe the pcm
wire frayed...i'll get that checked but still, any suggestions
Old Jun 6, 2007 | 11:16 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
take the bulb out
Old Jun 7, 2007 | 11:28 AM
MINIHEMI's Avatar
MINIHEMI
i want to take it out at this rate!!!
Old Jun 7, 2007 | 11:33 AM
das2123's Avatar
das2123
It comes back on because you have the code 21 problem.
