clear headlights
Old Jun 10, 2007 | 09:01 PM
justinsanders's Avatar
justinsanders
Default clear headlights
how do you make the headlights clear!!! i tried using 220 grit wet sand paper. then used turtle wax rubbing compound and buffed the headlights with that but all that did was take the yellowness out. it improved them but its just not clear. thanks
Old Jun 10, 2007 | 09:32 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: clear headlights
try some more with some fine sandpaper maybe 800 to 1000 grit then buff them again if you have a high speed buffer that would work best
Old Jun 10, 2007 | 09:35 PM
spudsterier's Avatar
spudsterier
so are you wanting them to have no yellow or clear like glass????
Old Jun 10, 2007 | 11:55 PM
justinsanders
Im trying to get it like glass. I will try to use a finer grit. but the headlights are so small and they have 3 little plastic nipples on them so i cant get my buffer in there.
Old Jun 11, 2007 | 12:54 AM
spudsterier
you cant get the clear as glass since the lenses have the lineson the inside ofthem....only way is to buy clear headlights
Old Jun 11, 2007 | 02:39 PM
justinsanders
all the yellow is out but you cant see through it at all ill post a pic tomorrow
Old Jun 11, 2007 | 07:30 PM
das2123's Avatar
das2123
ORIGINAL: justinsanders
Buy some Diamond clear's
Old Jun 11, 2007 | 07:36 PM
justinsanders
how much r they
Old Jun 11, 2007 | 07:39 PM
das2123's Avatar
das2123
About $90 from ebay.
CLICK ME
Old Jun 11, 2007 | 09:00 PM
rjab0196's Avatar
rjab0196
Get some Twin Halos...
http://cgi.ebay.com/ebaymotors/95-96...QQcmdZViewItem
