Code 31
Old Jun 14, 2007 | 06:33 PM
beast4192's Avatar
beast4192
Default RE: Code 31
Would code p1495 leak detection pump solenoid circuit is that just like a vacuum leak or is that something else.
Old Jun 14, 2007 | 06:40 PM
das2123's Avatar
das2123
Default RE: Code 31
ORIGINAL: alpinegreenneon
P-1495 Leak Detection Pump Solenoid Circuit
When monitored: Immediately after a cold start with ambient temperature between 40 and 90 degrees F and coolant temperature within 10 degress of ambient temperature.
Set condition: The state of the solenoid does not change.
Possible causes:
fused ignition switch output open
LDP solenoid short to ground
LDP solenoid circuit open
LDP wiring harness intermittant fault
LDP defective
PCM
The leak detection pump is by the evap canister under the splash shield passenger side behind the bumper. If wiring by the gas tank was messed up, it may be as well be messsed up by the LDP. Use an ohmeter to check the wiring from connectors to PCM for continuity and shorts to ground. Get new wiring from a junkyard if it's real bad.
Old Jun 14, 2007 | 08:29 PM
beast4192's Avatar
beast4192
Default RE: Code 31
I cant find the LDP I pulled the EVAP canister off and still didnt find it. Is it back by thegas tankand what fused switch would be blown.
Old Jun 14, 2007 | 08:43 PM
beast4192's Avatar
beast4192
Default RE: Code 31
OK i found a connector but there is just a plug in it. Its not going to any kind of pump unless it got ripped out of somewhere but i dont see anything thats broken
