Going turbo question
Old Jun 13, 2007 | 02:38 AM
johnneon's Avatar
johnneon
Default Going turbo question
I have a 97 Dohc and Im eventually gonna go Turbo,,Im in the process of getting what i need,,and i have a question,,And im hoping you guy's can help me out,,My question-Should i keep my Dohc piston's or go with Sohc piston's for low compression and is it a bad idea just to keep the Dohc ones..And im kinda new to the Turbo world..So..If any of you have any info..To send me down the right path it will be apreciated..Thanks..Oh and im going with the srt4 turbo,,
Old Jun 13, 2007 | 10:56 AM
spudsterier's Avatar
spudsterier
Default RE: Going turbo question
the dohc pistons work just fine......sohc pistons will get you lower compression but if your keeping the block stock anyways, then i would just keep the dohc pistons in there
Old Jun 13, 2007 | 01:02 PM
das2123's Avatar
das2123
Read through spud's how-to post.
Old Jun 13, 2007 | 04:19 PM
johnneon's Avatar
johnneon
Thanks..
