whining sound
Old Jun 19, 2007 | 01:30 AM
neonracer1010's Avatar
neonracer1010
Default whining sound
my tranny makes the sound in all gears as if it in reverse. like reverse whines when u get it wound up a little bit, thats what it sounds like in forward all gears. its a mtx
Old Jun 19, 2007 | 04:56 AM
johnneon's Avatar
johnneon
Default RE: whining sound
Have you checked your transmission oil to see if it is full???
Old Jun 19, 2007 | 10:46 AM
spudsterier's Avatar
spudsterier
did you get the other problem fixed???
Old Jun 19, 2007 | 04:17 PM
neonracer1010
got the other problem fixed, the clutch was bound up on the input shaft so i loosend all the flexplate bolts a tid bit and then pumped the clutch a few times tightended it uppulled outta the driveway and it wasfine so i decieded totake it down the road,like 3blocks and on the way there it was fine just sounded like reverse and i only went to third, then on the way back i went to put it in third and it made like this screeeeeeech sound so i never put it in third. so far since its been all reassembled ive put half a mile on it.[:@]
