what are these?
Old Jun 19, 2007 | 11:25 PM
neoncrazy101's Avatar
neoncrazy101
Default what are these?
sounds stupid but i dont know what all these things are in this photo...
I know theres the valve cover gasket, plug seals, head gasket and the things for the bolts, but what is everything else?
Old Jun 20, 2007 | 12:07 AM
spudsterier's Avatar
spudsterier
Default RE: what are these?
the blue things in the middle of the valve cover are your intake gaskets
to the left of those are your valve stem seals
top is the exhaust manifold gasket
in the head gasket on the left is your cam sensor seal
2nd spot should be the egr tube seal that goes in the intake manifold
3rd spot is for the other end of the egr tube that connects to the egr valve
dont know what the 4th is
Old Jun 20, 2007 | 12:15 AM
neoncrazy101
ok cool so the kit really comes with everything, alrighty, how do u get the old cam seal out?
Old Jun 20, 2007 | 12:16 AM
spudsterier
aha...thats what the one on the right is.....a cam seal...
if you use a screwdrive you can actually just pry it out......but you have to take all the timing crap off in order to get to it[&:]
Old Jun 20, 2007 | 12:18 AM
neoncrazy101
the heads already off so it shouldn't be too hard.
Old Jun 20, 2007 | 10:00 AM
spudsterier
since the head is alredy off you might be able to just push the seal out from the inside.....or you can pry it out witha screwdriver
Old Jun 20, 2007 | 12:23 PM
das2123's Avatar
das2123
If it's from Modern, then it will have everything you need.
Old Jun 20, 2007 | 03:14 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
all the other stuff is extra as how most gasket kits go anyways lol
Old Jun 20, 2007 | 04:30 PM
spudsterier
the guy that did my motor ordered a top end gasket kit and a bottom end gasket kit......cost about $275 for all of it......but there is a hell of alot of gaskets in there..i havent even gone through it to see what all it is, but the back lists every single gasket for the whole motor.....its pretty cool
Old Jun 21, 2007 | 05:10 AM
loud99R/T's Avatar
loud99R/T
the cam sensor is on the right hand side, right? right under where the stock intake hose would be right? cuz if it is mine is leaking oil something fierce
