Help with driver side window problem
Have a 2001 durango - the driver side window went down the other day and won't come back up now. All other windows work fine, as do door locks. Any help on this would be GREATLY appreciated[/align]
does it make any noise? if it makes noise i would say the window regulator if it dosent make any noise i would say window switch. if your desperate you can pull whatever it takes to get to the switch contacts. pull your fuse out of the window slot and if you take a 12 v battery charger (I used part of a 120 V test light and cut the wires so i had 2 probe type deals) and i played around with what contacts did what till the window went up on my father in laws busted *** mini van
thats what i was thinking
