mopar ecu?
Old Jun 21, 2007 | 04:34 AM
mulletman11's Avatar
mulletman11
Default mopar ecu?
gimme cost, power benifits, and time & difficulty to install
Old Jun 21, 2007 | 04:47 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: mopar ecu?
about 250 new
about 150 used
it claims to give you 8-11 horsepower to the wheels (i felt A LOT more power in the lower RPMs)
and it takes 5 minutes to disconnect your old ecu and put the mopar one on
Old Jun 21, 2007 | 05:31 AM
boxerjl2's Avatar
boxerjl2
ive heard you have to use 92 gas can you use any others??
or does it take away power?
Old Jun 21, 2007 | 10:48 AM
spudsterier's Avatar
spudsterier
you can use whatever ga you want but 92 octane will give you the best performance output
Old Jun 21, 2007 | 11:43 AM
das2123's Avatar
das2123
Using a lower octane may also cause your engine to start pinging.
Old Jun 21, 2007 | 02:26 PM
romeo21's Avatar
romeo21
now can i use a mopar pcm if i swap ina 2000 motor and witch pcm would i have to use
Old Jun 21, 2007 | 02:40 PM
das2123's Avatar
das2123
ORIGINAL: romeo21
As long as you keep your current wiring harness, then yes. You would need to use a first gen PCM.
Old Jun 21, 2007 | 05:10 PM
mulletman11
ok
got that, now
a. where is my current ecu located?
b. i simply plug it in, no reconfiguring?
and what is a pcm?
Old Jun 21, 2007 | 05:34 PM
das2123's Avatar
das2123
ECU=PCM
It's located on the driver's side right beside the fender. You can't miss it.
Old Jun 21, 2007 | 07:30 PM
neoncrazy101's Avatar
neoncrazy101
^ its big (least in the newer models compared to the 95's) and aluminum and has a block box connected to it through wires.
