tb
Old Jun 22, 2007 | 04:35 PM
winplet1971's Avatar
winplet1971
Default tb
what all is involved in using a 60mm jeep tb on a 2.4?
Old Jun 22, 2007 | 04:54 PM
das2123's Avatar
das2123
Default RE: tb
Alot. It's not a simple bolt-on.
http://forum.1gn.org/viewtopic.php?t=1555
Old Jun 22, 2007 | 05:04 PM
winplet1971
Default RE: tb
thanks alot doesnt look that hard will let you know how it turns out ,and what should i expect by doing this mod?
Old Jun 22, 2007 | 05:07 PM
das2123's Avatar
das2123
Default RE: tb
A loss in power if you don't have enough supportive mods.
Old Jun 22, 2007 | 05:15 PM
winplet1971
Default RE: tb
custom header,perfomance exhaustno converter,26lbs injectors,ud pully,cai,cran cams,comp springs,titanium keepers,and head is gasket matched and soon will be ported and polished is that enough to make it worth it?
Old Jun 22, 2007 | 05:33 PM
das2123's Avatar
das2123
Default RE: tb
Yep, but why do you have 26lb injectors? If you don't have a turbo, you don't need them.
Old Jun 22, 2007 | 05:42 PM
winplet1971
Default RE: tb
they were in it when i bought the car,should i swap back to stock injectors?i do want turbo,but that will be a while befor i can do that ole ladies got a bun in the oven,lol
Old Jun 22, 2007 | 05:45 PM
das2123's Avatar
das2123
Default RE: tb
Stock would be better. Remember more fuel does not equal more HP.
Old Jun 22, 2007 | 08:18 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Default RE: tb
Definatly change the injectors back to stock. It would be godo for you now since you dont have a turbo. But with the mods you listed you will be fine with a 60mm TB. Let us know how the Jeep TB works out for ya!
Old Jun 22, 2007 | 08:39 PM
winplet1971
Default RE: tb
ok 2 problems w the jeep tb one the jeep tb iac motor is on the wrong side and will not clear my intake and also what do u do with the vacum line cause the jeep doesnt have a port for it???
