Air conditioning
Old Jun 24, 2007 | 04:37 AM
joecool6101's Avatar
joecool6101
Default Air conditioning
First of all.. I have never delt with air conditioning.
Every car me or my parents have ever owned I think maybe only 1 had working A/C
I want mine to work now. But i am not sure how to go about it. I have a 96 neon... seems to blow air but that is about it. I am told that it can be very expensive to get it working.. but i dont have a ton of money so if there are any techniques that is always a + ..
I am not sure what to look for or how to tell its not working 100% other then the no cold air..
Thank you.
Old Jun 24, 2007 | 04:58 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: Air conditioning
you can get it rechargered for around $100
but try using the search box at the bottom of the forum because i remember a post being similar to this one
Old Jun 24, 2007 | 01:31 PM
joecool6101
I just searched and didn't really find what i needed.
But thank you for the advice.. How would I know if the pump its self is actually working?
Old Jun 24, 2007 | 04:08 PM
boxerjl2's Avatar
boxerjl2
whoa can yo have an AC if your heater core went out??
dont mean to steal the post but since its the same subject i just thought since it went out i couldnt have anything without coolant spilling everywere...
let me know
Old Jun 24, 2007 | 05:02 PM
turbodneonracer96's Avatar
turbodneonracer96
Just turn on your A/C see if the compressor cycles on and off. Ur rad. fan should do the same. If it does that means you have some 134a freion in your system but very little. Now go to Kmart or walmart and get a can of refrigerant with the hose attached. Then put it in it should stop cycleing when it is near full. Read the instructions on the can and you can do it.
