Mopar pcm and boost!
since you have ne zero mark, you use the timing pulley marks with an adjustable light to tell where your timing is, or make a TDC mark on the timing cover and pulley.
how are you getting half a tooth? are they on top of each other magically or what. you cant skip half a tooth unless you put a different key on the timing sprocket.
cam timing is one thing, ignition timing is another., advanced ign timing is bad, advanced cam timing might help it
