Mopar pcm and boost!
Old Jun 24, 2007 | 03:25 PM
turbodneonracer96's Avatar
turbodneonracer96
Default Mopar pcm and boost!
Can you run a Mopar with boost ?
Old Jun 24, 2007 | 05:02 PM
racerx55's Avatar
racerx55
Default RE: Mopar pcm and boost!
if you want your motor to detonate constantlyand blow up sure.
too much timing advance with a MP pcm, use the stock one.
advanced timing and boost dont mix or this happens
[IMG]local://upfiles/37714/7F3A493437884BF7B9597278B7E346BA.jpg[/IMG]
Old Jun 24, 2007 | 05:26 PM
turbodneonracer96
Well i know ima a half a tooth advanced on the crank so if i go back to stock then ill only be a half a tooth advaced so will thaqt be ok.
Old Jun 24, 2007 | 05:28 PM
turbodneonracer96
I did not put any boost to my motor yet im just running a mopar naturally aspirated. Is that ok. my plugs are kinda dark now. so if i go back to a stock pcm will that half a tooth matter.
Old Jun 24, 2007 | 07:16 PM
spudsterier's Avatar
spudsterier
any timing advance can cause you problems
Old Jun 24, 2007 | 09:24 PM
turbodneonracer96
I dont think a half a tooth is gonna really matter that much.
Old Jun 25, 2007 | 12:08 AM
das2123's Avatar
das2123
To run a Mopar PCM with turbo you would have to use a piggyback ignition that can retard the timing about 25° +.
Old Jun 25, 2007 | 02:17 AM
turbodneonracer96
like an msd 6a. And if so how do you make sure its retarded.
Old Jun 25, 2007 | 03:06 AM
dcmcguy's Avatar
dcmcguy
hmmm, i'd just hit it until it starts drooling
Old Jun 25, 2007 | 05:39 AM
SOHC TURBO's Avatar
SOHC TURBO
haha omg, i just laughed outloud to myself
